nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Mar 27, 2014 4:44 pm
The only way to "tune it down" is to send it to someone that can chip the ECU to the specs you are looking for. This will normally take to get it socketed, which is the part that is tricky. Conceptzperformance, specialtyz, Z1, all are places that can do it for you. This is something you do not want to tackle on your own. You need the software to write it and the knowledge on how to get the fuel parameters correct.
The only other option is to buy a USDM ECU, which essentially will cost the same. With a tuned ECU, it will get you more ponies and you will be able to boost higher than stock. A non- tuned ecu will create a lot of havoc if you turn the boost up from 9PSI.
