uvamosk »
https://forums.nicoclub.com/uvamosk-u30063.html
Sat May 13, 2006 6:49 pm
I dont know what it could be seeing as all i did was swap the trannies take the AUTO trans harness out and ran my back up lights and hooked up my speed sensor and spliced the two wires to get the car to start. It was the 2 big ones behind the battery i think they where white and white/black. I can't figure out why the car would just start doing that.... But it also idles really high also... at about 1,500 rpms.. since i swaped the fuel injector when i found out one was bad so i might need to do a idle adj. or something .. Do any of you know if there is a way to back the idel down????
other than timing because timing is fine...
