Automatic seatbelt......
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
Touge noob S13
Car: 1991 240SX coupe
I have a problem with my drivers side automatic seatbelt. It does not move in sometimes when I close the door although the passengers side works perfectly. Does anyone have any idea what the problem could be?
Modified by Touge noob S13 at 4:13 PM 10/6/2007
ChuckNC
Car: 1992 240sx hatchback
I had the same problem with mine soon after I got my car. If I remember correctly, the grease gets into the micro switch mechanism and the sensor thinks the seatbelt is already retracted. If you take it apart, you can clean it out. It's not that tough to take apart and reassemble.
Just for kicks, tap on it when the ignition is on and the door is closed to see if it jars the sensor loose. Then, you'll know that is the problem.
WhiteKnight
Car: Nissan 240SX
Unplug the computer that makes it move............the whole thing is annoying
Return to “Interiors”
