Automatic removal Q
nightkid86
Car: 97 S14 SE
In the process of a 5 speed swap. dropped the transmission but there is one sensor in the A/T that will not unplug and has a bunch of wires running into the A/T bellhousing. Should we cut it?
hoping to use the AUto ECU/ OBDII s14
this sensor thing is on the back right side of the transmission bellhousingModified by nightkid86 at 9:52 AM 6/16/2006
Modified by nightkid86 at 9:53 AM 6/16/2006
180fan
Car: 89 fastback
you should keep that one. if you've got a kouki it'll trigger a CEL
