Automatic Overdrive Problems 93 vert
fenderman33
My 93 convertible won't shift into overdrive now. Shifts hard between first and second and second and third under anything except heavy throttle. Fluid level is fine.When you turn the key on the OD OFF light will blink the two times then blink 16 more times and then stay off. I tried doing the blink code check, but it didn't work for some reason.If someone could help me out that knows what's going on, I'd appreciate it....or who wants a 99k mile vert. haThanks-Jon
240sxRAOR
Car: Nissan 240sx Convertable 1992
Hey Dude I was having problems with mine too, I lost the over drive an then I lost first gear too. It sounds like it might be slipping, I would suggest getting a trans oil treatment, they are like ten bucks at any auto place and its worth a try. Its either that or the transmission is getting old, auto's don't last forever you know. I plan to change mine to a five speed soon, its a massive difference and its cheaper.
Eikon
Car: 71 240z, 93 Supra TT
Hey guys. Sorry to take so long to get to you.
I'm not sure where to point you for those transmission issues.
Here's one idea... But it doesn't seem to quite match the description you listed. Give this thread a read.zer...age=1
First couple pages describe problems with shifting. last couple pages get down to fixing it.
I would suggest posting in the Nissan Online Mechanic section. Maybe Nistech can help you sort out the transmission issues. zeroforum/23
Welcome to NICO by the way.. Hopefully we can help you get to the bottom of this.
guyaverage
Car: Nissan 240SX Convertible
Is the fluid pink/red? Does it smell burnt at all? If fluid condition is ok, I would suspect either the throttle position sensor (TPS) or possibly the speed sensor. I would check the TPS first.
kc240guy
Car: gold s13 and a maxima
ok i see noone read mine
fenderman33
The fluid is in correct color and level. The speed sensor works fine. How would the TPS keep it from going into OD? No matter what I've done with the throttle it won't shift down.Jon
kc240guy
heres the sensor to unplug
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
I finally got around to unplugging that top wire you circles in the picture and have not had a shift problem since. I know by reading this thread that this is a backup relay but don't remember reading if a replacement was ever found or even needed.
fenderman33
I unplugged that connection with no change.Anything else to check?Jon
