Automatic lights and wipers
All things Altima Coupe.
photoframd
Car: 2008 Altima Coupe 3.5SE
Can the automatic lights be set to automatically turn on when the wiper blades are in use?
Rolling Estonian
Car: 2008 Altima Coupe 2.5
I believe it can be done. It won't be a setting though, but a custom electrical wiring setup. you'll need to wire in a normally open relay parrallel to the headlight switch((es), on and auto as well)). best bet, find or make a friend who is an industrial electrical tech, someone who knows Electrical controls and logic (key words).
GryStrm
Rolling Estonian wrote: Electrical controls and logic (key words).
logic....as in if a+b=c and c is the sum of d+e then (a+d)-(b+e)*c=0 ?
photoframd
I believe the clinical diagnosis is "princessitis lazyasseous".
I swore that I would never use them, but it really is easy to fall under its spell.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Logic as in electrical inputs, from various sources, into a computer that in turn "computes" those signals into a usable signal for another item
leifab
Car: 2011 370z Touring sport
I think he was going for the other way around.....that anytime the wipers were turned on, the lights would come on. Which makes sense. Best bet scenario would be lights come on in the "auto" setting when the wipers are used and stay on for the 30seconds or so if the wipers were only used once. That way you wouldn't have the lights going on and off for just a quick swipe.
And now that i think about it....instead of tying the wipers to the lights, tie it to the light sensor, so that way when you turn on your wipers, your lights "think" its dark out.
Rolling Estonian
adidas2go wrote:Logic as in electrical inputs, from various sources, into a computer that in turn "computes" those signals into a usable signal for another item
thanks adidas, I'm not so good with the layman.
leifab wrote:And now that i think about it....instead of tying the wipers to the lights, tie it to the light sensor, so that way when you turn on your wipers, your lights "think" its dark out.
Leifab, you might be right, provided photoframed kept his light switch in the "auto" position, which I do anyway.
...yeah instead of a normally open relay parrallel to the headlight switch. you need a normally closed relay in series with the light sensor.
photoframd
The issue is NY and other states require the headlights to be on if the wipers are engaged for a period of time. I was hoping that Nissan would have considered this already and programmed it in somewhere.
Charles
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
having HIDs if you do a quick wipe of the windows and your HID turned on it wouldn't be good for them. Man I wish the car controller was controlled by a software we can tweak and rewrite the logic w/ code hehe. Of course it won't be as reliable, safe bcuz of crashes hehe
