automatic KA-Ts
GZer01ne
Car: Black 1995 Nissan 240sx
I know, heresy. but if you have an automatic kat or know someone who does, tell me as much as you know about it. seems like a nice combination of sportiness and daily drivability. and yes, i did search, but i'm looking for personal experience.
p.s. - i know, use the money for a 5 speed swap. and i probably will, but im curious.
shimizu_17
few people on here have auto ka-t's and seem to work fine. Just get really good transmission fluid and a transmission cooler if you can.
S13FX
Car: '69 l20b Dimeski :)
Hey auto trannys on KA-T are fun *** hell.
Just like mentioned before get good transmission fluid, a decent oil cooler, and a high stall converter.
And you will have a world of fun. The fastest KA-T by Ivan running high 8's I believe uses an auto transmission.
GZer01ne
really? I would love to keep my 240s transmission until it decides to give up the ghost, and if I really want pick up another project that is manual. I would probably run low boost just to nab about 200 hp, so maybe this is the route i should be exploring.
neverlift
lol I just got done telling a friend to spray a 50 shot on his auto transmission and it would be fine, didnt believe me
S13FX
I did forget to mention though when Ivan ran the 8 in his 240 it wasn't the KA-T transmission. But at least it was a KA ....
neverlift
no, I know wasnt it the 300zx transmission? dont recall
w/evar kat ftmfwauto rocks for the 1320 lack of human error owns
240-slide-ride
Car: pignose
hmm its on youtube the vid if i recall he was using a gm trans th350 i believe but dont quote me on that
Garrett0x
Car: 1995 240sx KA-T
Im running an autotragic in my KA-T. I usually dont have any problems except for when I realllly get on it, it likes to slip a little going into 3rd. But other then that it shifts awesome. Ive read of people modifying their setup for 300zx trannys as well as ford C4's, those things are pretty much indestructable.
WDRacing
Current transmission condition is really what matters the most. High mileage trannies have alot of material worn off of the clutch packs. At a minimum I'd use redline oil and a big oil cooler. If the transmission is in good shape it will hold just fine.
If you ever rebuild it, you can send the stall converter to Precision Industries and they'll ramp up the stall for you and replace all the guts inside it. Which would make your car an animal off the line
WD
eazye2000
Car: S13 KA-DET
Good info WD. I didn't know you could send off your stock converter out.
My car has 134k on it. I'm going to swap the fluid, and add a nice sized cooler. I believe a thermostat for the cooler would be a good thing so you don't hurt your transmission by beating on it if its not warmed up. I'm not completely sure though.
If anyone wants to contribute a T3 turbo, send it over. It's all I need to boost the S14..
GZer01ne
will I need the transmission cooler if I stay around 200 hp? Also, this may be another topic in and of itself but what turbo would you recommend for a very mild setup. I was thinking T25 but I hear it only runs at 7-8 psi.
480sx
Car: 1996 Pearl White 240sx
Eric, i got a t3 super 60 that i would let you snag for 75 shipped. Its been sittin for a while, but the wheel spins freely and its got little to no shaft play. Judging from the shaft play the turbos in great shape.
Hit me up, my emails in my profile.
BTW, WD pwns your profile.. Lmao
S13FX
eazye2000 wrote:Good info WD. I didn't know you could send off your stock converter out.
Dude you should turn a radiator into a transmission cooler :-p
