Id like some help with this an did alot of searching
EckOMaN2k wrote:Im just trying to figure out before i drop some money down on building my transmission on what do i need i did searching on this board an they usually say just get a high stall torque converter an a transmission cooler? Is that true an also if i get this were can i get it from only place i know of is level 10 an they charge freakin $1000 for a bullet proof torque converter that is way too much money. So does anyone know of a place were i can get a torque converter for cheaper also a transmission cooler?
is this going to be a daily driver? imo, high stall converters and lightweight flywheels are overrated. i've driven a car with a high stall converter and it sucked. it was fun for racing, but that's it.
Oh yeah if you have anymore tips on transmission buildups please let me know, because i only want to run like 12psi or so off the greddy kit for now.
the automatic transmission is a pretty stout piece. i plan on running boost on mine, and the only buildup i'm going to do is switch to redline transmission oil. for day to day driving and the occasional race, i don't see a need to add a transmission cooler.
Also in a automatic transmission does the BOV go off when it shifts or only when you let off the gas?
the bov will open only when you let off the gas.
-demetrius
