jtsarnak »
https://forums.nicoclub.com/jtsarnak-u3215.html
Tue Jul 27, 2004 2:38 pm
Quote »If I'm sitting at the lights with boost already sitting at 1 bar and your simply sitting at 4500 rpm, who's gonna have the better 60' time.[/quote]
Are you saying that you can sit and build boost assuming you have a different stall on your torque converter? Or are we talking stock?
Also, since i don't know a whole lot about automatic trannies, is a higher stall converter one that allows no transmission of power until that RPM is reached, and then suddenly starts pushing power? For example, if I have a converter with a stall of 2000 rpm, does that mean I can rev anywhere between 0 and 2000 and the car just sits there, and then once I get above 2000, the car takes off as if the clutch in a manual transmission was just dropped at that same rpm?
If that is the case, what does that do to regular driveability. Does that mean that when I let off the brake in the auto car with a 2000 stall that it doesn't creep forward like normal, because it only idles around 750 rpm? What about in parking lots where small adjustments or low speed turns are needed? Does the car not respond until 2000 rpm making driving at low speeds in tight quarters really erratic and scary?
