szh »
https://forums.nicoclub.com/szh-u149.html
Fri Feb 16, 2007 7:29 am
Welcome to NICO!
There is a sensitivity setting that you can adjust for this. It is on one of the setup screens. I have the older 2003 model, so cannot give you the exact button presses, but it should be described in your owner's manual.
If, as you noted, this setting changes are insufficient, you should definitely have the dealer look at the car and test the light sensor, etc.
Z
