Promise Land wrote:Are you looking for headlights on with the key like DayTime Running Lamps (DTRL) or something that comes on the a sunlight dusk sensor?
Don't know about the OP, but I'd like headlights that turns themselves off when I turn off the car. Should be easily done by setting up a relay connected to the headlight switch and takes signal from the wire for either ACC or ON from the ignition switch.
At least, that's my theory. I don't know which wire to tap onto for the signal, or for the switch for that matter. I'm by no means an electronics expert.
