automatic ECU
PapaSmurf2k3
Site Admin
is the automatic ECU for the DE just plug and play and it erases all speed limiters? everything els is the same right? Im thinking about buying one so I dont have to deal with all the speed limiter crap anymore. Thanks.
mkory
Car: Mazdaspeed Miata
I think if you're using it on a 5 speed you're check engine light will be on due to not actually having a manual transmission. Other than that, from what I hear, you sir are correct.
Structure240sx
pop the light bulb out, forget about the codes
the idle might not be perfect, slight differences there. the car will still run fine tho, try it out cant hurt.
if you have an s14 i have an extra auto ecu
PapaSmurf2k3
Site Admin
nope, S13, but thanks anyway... ill pick one up off ebay and give it a shot and post my results.
WDRacing
Tony, I want your auto ECU...email me so I can try it out, if it works, I'll buy it.
[email protected]
mkory
May I ask why you need to go above 120 MPH?
Structure240sx
speed limiters on 240's are actually about 115.
certain people need to go past that just at the drag track, especially if your tires are shorter than stock your ecu sees higher speeds
otherwise some are interested in top speed, i admit its fun but i dont do it too often. most i have ever gone was about 125.
just talked to someone the other night wondering why i havent topped my car out. they dont understand NJ roads and police
WDRacing
Exactlt, 120 down the 1320 and highway racing. 115 comes up way to fast when your racing almost anything with a V8 nowadays.
