Automatic Driver Postioning system does NOTHING
mludy
Car: Infiniti Q45 base model
I recently had to remove the battery from my 94 Q and now the ADP system does not go back when you turn the car off any help would be great
(I found a half way similar post in a different forum, but I thought for future reference this problem could be addressed here)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It's been addressed many times here in the previous posts and is also in the FSM.
Please include MY in your profile.
goody90q45
Car: 1992 Infiniti Q45 (sold)
mludy wrote:I recently had to remove the battery from my 94 Q and now the ADP system does not go back........
Try this:
Disconnect the battery cables for ten minutes, reconnect, then follow these steps:1. Open the driver front door2. Turn the key to the Run position (all the instrument cluster lights on, but engine not running)3. Turn the key all the way back off, but don't remove it4. Close the door5. Wait about 1 minute (no less)6. Open the door. Your seat should slide back, the steering wheel should tilt up, and the memory function should work.
