elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat May 03, 2003 5:26 am
Ok, and installing them is as easy as unbolting the 2 upper nuts and the lower nuts?
Ok, back to the memory thing, I got the procedure, and I tried it with no luck. Here is what I did:
Opened drivers door, turned key to run, turned key off (but didnt press in the button to take it so you can take it out), closed the door, waited 1 min, and open/closed drivers door 2 times.
Is that the correct procedure??
Also, in the service manual (p BF-80 in mine) it has the self diagnosis procedure. Is it the same for a 1990 Q as it is for my 1994?
