automatic box
kouki_monstor
Car: '92 180sx
I'm doing a 5 spd conversion, and while I was in the process of installing the clutch pedal, i noticed a black box in the place of where the clutch pedal should be. the screw that holds up the pedal is holding that box up. the box is connected to the subharness and everything, so im just confused as to how I could install the clutch pedal with the box in the way. Im just wondering, what is that box and is it really necessary? Could I just remove it or ziptie it up somewhere else so I could have room for the pedal? Please help I've been searching but couldn't find any solutions. Any ideas would be great. Thanks!
180fan
Car: 89 fastback
Zip tie it away.
kouki_monstor
Car: '92 180sx
Any ideas what it does? Thansk for the suggestion!!
180fan
Car: 89 fastback
Shift lock control unit. Without it you won't be able to get your key out of the ignition.
hope that helps.
