autocross shcosk and struts
sentranator
Car: cars and hockey
hey guys im bilding my 91 240sx with super hicas for autocorssing. right now im gettign parts for the suspension i wanted to use the kyb adjustable shocks and struts with eibach sportline springs and cusco camber plates.
first question can i use those kyb adjustable with super hicas??
also do you guys have any product review on these products.. has anyone usesed these, have any complaints, or other recommendations?
does anyone do any autocrossing in south florida??
thanks guys this will help me out alot
Jason
Meantime
First: Yes, you can use KYB AGX or any other shocks with HICAS. It makes no difference. Don't pay attention to the disclaimer, it doesn't apply to the 240SX.
Second: I've had the AGX for about 3 months now with heavy-duty springs, I have no complaints about the ride or handling, both are pretty good. If I had it to do all over again I would have picked Koni's instead of AGX, but only because my spring rates are higher than the AGX is rated for.
Third: Not yet...but give me a few months...:D
sentranator
alrigth thanks yea i was wonderign about that discalimer.. i also read about another guy who used the kyb with eibach sport lines he said they handled great so thats where i got the idea from i think for rigth now thats the route im going to go....... i also found the cusco camber plates for 60 bucks slightly used but makes no difference to me
thanks brother for all of the advice could luck with your 240
jason
Meantime
Anytime...one last thing, when you install the rear AGX make sure the adjustment dial is facing inward towards the diff, not out towards the wheel. The instructions that come with it are incorrect. The bottom peg that the rear strut bolts on to is slightly tapered and the strut's mounting ring is beveled to match it.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
I have a HICAS model with the AGX and Eibach sportline springs. It is a great setup and although there is not as much adjustability they still perform well. I put my shocks on 1/4F3/8R for street driving in SoCal and It is stiff but not backbreaking. The Stiffest setting is quite stiff for street driving. I haven't had a chance to track test it yet for grip driving, was excellent for drift though.
Install was not a problem at all. that disclaimer is total B.S. I've had mine for about three years now and never had any problems with them at all. They still adjust as if they were new. They were the perfect setup for me when I bought them cause it was only $260 for the shocks and $190 for the springs. You may as well just go with coilovers for what you are gonna pay for them nowadays.
the only problem is it does sit a little low and my exhaust occasionally scrapes on some of the demon speedbumps we have out here in cali. Hope this helps.
