So, I got bored and I have decided to throw a turbo on the KADE that I swapped into my S13 last spring. I originally was building the car to D Street Prepared specs for SCCA Solo2 use. (Build thread here:
zer...age=1)
I'll still be autocrossing this as well as using it as a DD since I will be selling my S14 in the spring. The turbo will throw me into the Street Modified class where it will not be remotely competitive. This doesn't matter to me so much since I will be out of my region for most of the events anyway, plus I'll still be running on street tires. I'm just looking for a little fun, and I've missed having a turbo car since I wrecked my other hatch. I'll be happy with around 250whp, but the turbo is probably good for a bit more.
List of parts to be installed:
-Pulsar GTiR T28 .86 a/r turbine with S14 T04B compressor-Nistune-Innovate LC-1 wideband-SSAC manifold and turbo dump-No name SR20 downpipe (still have this laying around from my RB20, hope it fits ) -480cc S15 SR20DET injectors (rebuilt)-CX Racing S13 SR20DET intercooler kit-1st gen DSM bypass valve-Walbro 255lph fuel pump-N60 MAF-Oil Cooler w/ thermostat-Mishimoto aluminum radiator-Taurus electric fan
I'm considering running a blow through MAF setup to reduce clutter on the exhaust side of the engine bay, but I'm not sure yet. I have the Nistune installed already...It's pretty cool to play around with. I'm guessing the worst part of this will be getting the cheap IC kit to fit properly, but it wouldn't be fun if everything just bolted together now, would it?
Aside from the engine stuff, there were a few issues with my suspension setup last year. One of these was that the Whiteline sway bar end links did not allow me to eliminate sway bar preload. I'm getting some PDM adjustable links. Also, I'll be backing my alignment off a little bit to around 2 degrees in the front and 1.5 in the rear. The 3*/2* setup from last year was done to accommodate R-comps, which I never ended up getting. A less aggressive alignment will be better for street tires, along with tire wear since I will be driving this every day. I will be running zero toe front and rear to reduce tire wear. I can't achieve zero toe with the stock arms in the rear for some reason, it's actually toed out. I obviously need adjustable rear upper control arms and toe arms (or something is bent, haha). I'm going to run significantly softer springs so I can stand driving around town, plus the street tires don't like the super stiff springs. I'll also be swapping the Nismo LSD for an S15 helical unit for better streetability, plus it will be better for an autocross application. I'll need to get rid of my hockey puck engine mounts and throw some stock or Nismo mounts in there instead since the car shakes like crazy with those things in.
I just picked up some 255/40R17 RE-01Rs for $360 shipped, so I need to find some 17x9s and some 5 lug hubs to go along with those. I'm considering MB Competitions, FN01s, and RPF1s. I'd like to go with the Enkei's, but we'll see what my wallet has to say about that.
I don't want to do a whole lot more to this chassis since it is pretty rusty underneath (not dangerously rusty, just too much work to justify keeping the chassis). I plan on finding a clean shell once I graduate and find a job/place to work on the car (big variable right now with this awesome economy). Then I can really go all out and make an actual track car to do HPDEs and eventually time trials with.
I'll update the thread once it is above 20 degrees here so I can actually do some work...
Modified by nissanman04 at 3:58 PM 2/24/2009
