[email protected] »
https://forums.nicoclub.com/john-240sxmotoring-com-u128429.html
Fri Apr 03, 2009 5:49 am
Most auto-x's are just arrive and drive, i.e you don't have to sign up as a member or run the entire season.
My advice would be to make sure your car can pass tech (battery tie down, brake fluid, pads, wheel bearing, entire cockpit is clean(no floormats, debris to roll around,etc)) then you're good to go!
