Auto Window Up problem?
biggie
Just wondering if anyone is having an issue with the Auto Window up on the driver's window (only one that has the option I guess). Mine has not worked since I had the car, just didn't know if it was common.
The auto down feature works fine. And the up worked on my '02 Pathfinder, so I know what its supposed to do.
I'll be taking it in within a few weeks for the dealership to investigate.
PB
Car: 2007 Nissan Versa S
Mine works fine,I just pull up and she gos up by it self.
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
From a previous thread: "When power is disconnected the auto-up feature has to be reprogrammed. You should just have to roll the window down a little more than halfway and then roll it back up but when it gets back to the top hold the button in the up position for at least 4 seconds."
coxcj
Car: 07 Nissan Versa SL HB Sapphire, conv pkg, audio pkg, sunroof, 5/07 mfg date, 6/2/07 purchase
Try the solution that has been posted in other threads. Roll the window up and hold the up for an extra 10 seconds. Then try the automatic down and up again. If that doesn't work, get the dealer to check it out.
biggie
10-4, will try that today.
Thanks peeps. I know they let the battery die on the lot before I bought it, so I'm sure it lost power.
biggie
That was the issue, got it reset at lunch.
Thanks
