marlin29311 »
https://forums.nicoclub.com/marlin29311-u97240.html
Mon May 18, 2009 5:49 am
Here's what you have to do for the same problem on an Altima - I would assume it's the same for my G bretheren...
1. Push the ignition switch to the ON position.2. Open the window more than halfway byoperating the power window switch.3. Pull the power window switch and hold it toclose the window, and then hold the switchmore than 3 seconds after the window isclosed.4. Release the power window switch. Operatethe window by the automatic function toconfirm the initialization is complete.5. Perform steps 2 through 4 above for otherwindows.
EDIT : Yup, I was right - The procedure is on page 2-52 of the owner's manual for an 08 coupe.
