Auto window switches??
All things Altima Coupe.
bmann
Car: 2010 Altima Coupe 2.5S
I have a 2010 2.5S AC. No convience package. My Drivers window is an Auto switch, but would like to have the passanger switches be the same also. Does anyone know if I could replace the non auto switches with Auto switches?
Thanks for any info..
boystar22
Car: 2008 Nissan Altima Coupe 2.5S
The auto switches have more wires in the harness and use a larger plug, so just as a visual non functional feature it would require rewiring the door harness' and getting a hold of the correct plugs for them. If you were hoping to also make the auto feature work, you'd need to not only do the above, but also replace the window regulator and run the extra wires and possibly replace the window motor as well. It isn't an economical upgrade if you didn't purchase a car with it already.
Been there, thought of that. The steering wheel radio controls are easily added, and the heated turn signal mirrors aren't impossible to do, but the auto windows, or the digital HVAC controls are cost/labor prohibitive.
