Auto Window's Up
All things Altima Coupe.
domdada
Car: 08 A/C 3.5 CVT
I recently unhooked my battery to do some work on my A/C and when I finished and hooked the battery back, the Auto Window Up was not working. Is there some type of programming that I need to do to get it to work again?
desertdragon
Car: 2008 Altima coupe 3.5 SE with CVT Winter Frost
Yes. Someone did a write-up here some time ago.
You can check your manual.
domdada
Car: 08 A/C 3.5 CVT
Found the Post on that....And it's working again. Thanks for the info.
LegendRacer
wheres the post lol...im planning on doin some work to my car wwhich requires unpluging battery... just incase i fall in the same problem
bina12834
Car: 06 G35 coupe
all you do is roll your window half way down, then roll it up and hold the button for like 3 seconds after its all the way up
domdada
Car: 08 A/C 3.5 CVT
If your car is an 07 model or higher this is what you do.
-With the windows up, press and hold the window button to go down (not in the auto position) and after it's down all the way, hold it for 3 seconds more.
-Now with the windows down, pull the window button up so the window come back up (not in the auto position) and when the windows is up all the way, hold the button for 3 seconds more.
This should fix the problem. I did it and it worked.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Its on page one of the Table of contents.. and in your manual
vballer22
Car: 2008 altima coupe 2.5s
stsxcrle
hmmmm on the how to/read first page in general:
http://forums.altimas.org/zerothread?id=326810
