Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Wed Oct 27, 2004 4:48 am
There's a lot of noise out there about things like this. People say lots of things. For example, if you read the Skyline forums you can find people talking about how much power you can gain by "resetting" your ECU, or by going out and thrashing your car so that your ECU "learns" to drive your engine harder. I'm not saying anyone is wrong or right, but the fact that there is so much discussion tells you that the effect must be rather small, if any effect at all.
But without a comparison of the ROM files, side-by-side, there's no real way to know. Nissan isn't going to tell you, and it is impossible to measure on a dyno (due to the auto transmission).
FWIW, I put a '95 KA24DE with auto ECU in my 5-speed '89 with no troubles. The engine pulled hard, and I was very pleased with the result. Still, only a dyno could tell you whether or not a 5-speed ECU would have pulled harder.
Carl H may have a point, but I would guess that if the ECU does retard timing for shifts, then it would need a shift signal from the auto transmission controller. If you install it in a 5-speed car, then there will be no shift signal, and thus, probably no timing retard either.
