Long weekend here in NZ,
So i'm putting a vh45 into my nissan patrol. I pulled down my patrol auto box and put in the guts from the auto that came with the v8; the v8 box has more plates in each clutch and also a longer input shaft and fixed stator spline. etc.
I've had a quick look through here and i see one other who has rebuilt his trans- this was my first and I simply bought a generic book on auto trans rebuilding which was great. (Have since discovered the fsm)
I'm wondering if anyone can help me modify the factory valve body (either the v8 one or the one thats in my patrol box) to give harder shifts and increased line pressure. eg which holes get drilled and which accumulators get shimmed.
Also, I manually shift the auto trans via a set of relays wired into the inhibiter switch and the shift solenoids. There is no trans ECU and I have no power going to the line pressure release solenoid so its at "max" line pressure all the time at present.
cheers,
nathan
