Pescakl1, that is incorrect.Pescakl1 wrote:The problem is there is no auto-up window on the Rogue
The Leather Package comes with and Auto-up/down drivers side window. Lesser models come with auto down only.
It's not that simple. You would need both the motor, the power switch assembly and additional wiring. Reason: There is an anti-pinch system with sensors that will roll the window back down if something gets caught... much like the auto-reverse on a garage door opener.orijin wrote:can u actually replace the motor with an auto up and down motor? would be a little more convient when i want to open and close my rear windows like my friend's 3 series.
This turned out to be very helpful after replacing the battery in our Rogue. Auto up was no longer working.philipa_240sx wrote:If you are having trouble with the Auto-up feature (Leather equipped models only), try the following to re-initialize the power window:
INITIALIZATION PROCEDURE (From Nissan)1. Turn the Ignition switch ON.2. Open the window-all the way DOWN.3. Pull all the way UP on the switch and hold (close the window). Continue holding the switch all the way UP for 4 seconds after the window is closed.4. Confirm the window is now operating correctly.
How is it misleading? Do you have the "A"? If so, are you saying your auto up isn't working? Have you had it checked at your local dealership?Nissan6 wrote:Hi Everyone,
I'm new to the site but I do have something to say, in the 2009 Rogue, the owners manual is not clear about the auto up and down feature. It states that if it is marked with an "A" it is auto up and down. It appears that this is not the case as there is only an auto down on most vehicles. This should be clear because it is misleading.
Actually, the manual shows there are two types under Instruments and controls 2-41, but it doesn't specify the difference and requires you to read the detail.Rogue One wrote:How is it misleading? Do you have the "A"? If so, are you saying your auto up isn't working? Have you had it checked at your local dealership?Nissan6 wrote:Hi Everyone,
The switch does have the "A" but is only auto down. Dealer agrees that what is written in the manual is not clear.Rogue One wrote:How is it misleading? Do you have the "A"? If so, are you saying your auto up isn't working? Have you had it checked at your local dealership?Nissan6 wrote:Hi Everyone,
My 09' Canadian Nissan Rogue has the "A" on the driver's window switch...it goes auto up and auto down...Nissan6 wrote: The switch does have the "A" but is only auto down. Dealer agrees that what is written in the manual is not clear.
Yep, it's pretty straight forward. The manual clearly states (irregardless if it's TYPE A or TYPE B - that only indicates how the switch is notched) that if it has the "A" symbol it is auto up/down. The dealer is blowing smoke up your skirt. Try a different Nissan dealership, or independent shop.harryg wrote:My 09' Canadian Nissan Rogue has the "A" on the driver's window switch...it goes auto up and auto down...Nissan6 wrote: The switch does have the "A" but is only auto down. Dealer agrees that what is written in the manual is not clear.![]()
dealer=
I had quoted the manual for a 2009 Rogue (USA) few posts prior.Rogue One wrote: Yep, it's pretty straight forward. The manual clearly states (irregardless if it's TYPE A or TYPE B - that only indicates how the switch is notched) that if it has the "A" symbol it is auto up/down. The dealer is blowing smoke up your skirt. Try a different Nissan dealership, or independent shop.
I checked out your site and the irony is that you don't have the Rogue model listedSwitch Doctor wrote:It really depends on if the vehicle came with the option for up and down, you can see if your option does by looking at the switch here http://www.switchdoctor.net/
I can confirm that this reset works on the 2012 Rogue S. I had to do it this weekend after replacing my driver's side window.philipa_240sx wrote: INITIALIZATION PROCEDURE (From Nissan)1. Turn the Ignition switch ON.2. Open the window-all the way DOWN.3. Pull all the way UP on the switch and hold (close the window). Continue holding the switch all the way UP for 4 seconds after the window is closed.4. Confirm the window is now operating correctly.
AFAIK there are no tech bulletins regarding faulty power window operation. The procedure shown above covers all Nissan models with auto-up windows and is general information in case there is an issue. If the auto-up window stops operating again, I would take it back to the dealer.
