Auto turbo or Auto SC???
weg240sx
Car: 1995 240SX, 2008 Altima SE
Ok, I have a 1995 s14 w/KA24DE. The thing is it is has an automatic transmission. Has anyone put a turbo on this engine, with an automatic transmission, or supercharged this engine with an automatic? I have seen bits and pieces about adding an oil cooler and putting in a shift kit. I understand the oil cooler. Not real clear what the shift kit is or what it will do. My guess is that it could be done, with out raising the boost too high, with standard injectors, but it would probably need a better fuel pump. What about the electronics, what has to be done to the ECU to allow a turbo or SC 2.4 to run right. Just looking into it now, I just have not found the right '95 5spd for this project.
