auto trunk switch
rickie d
Car: 1987 nissan maxima
my 1987 max dash trunk release does not open trunk i can hear it click but trunk does not open,what could be wrong an how can i fix.
thanks in advance
BMAR240SX
Car: 1993 Nissan 240S Coupe
Did you check the gas struts?
Gerald-NC
Car: 1990 Maxima
Inside the trunk, right behind the license plate area, you can access the latch itself. There's a tab you can feel with your hand. Try to lift that tab up. That's what's happened with our 90, and I figured this out. I think it's a matter of the spring not pulling the latch back up. Got so bad our trunk wouldn't shut and so that got annoying and that's when I found mine like this. So now everytime I use the button to pop it, I check that tab with my hand before closing the trunk, and that takes care of it :D
rickie d
thanks ill try it.
rickie d
gerald found the problem in the area where you said push lever up there is a cable attached to the switch itself,it had slack in it loosened the bracket and loosened the switch took slack out of cable and now it works.
