Auto Transmission Problems
Kaikias
Car: 92 Nissan 240sx Ka24de
Well about a month ago I chaned the transmission fluid in my car, ran fine for a while. Last night jumped in the car, and now the torque converter is holding for about 20 seconds before is starts slipping. Did some reasearch found that it may be a clogged transmission filter. Anyone had this happen, or have any insight into this.
yellow_jacket
Car: 95 240sx
It is worth a shot to change it.
Just drop the pan, change the filter, reinstall the pan and fill it. If it works great. If it doesn't, then time for a new transmission.
Are you sure it is not pulling out of gear when it tries to shift? Have you tried manually shifting it?
Kaikias
Yeah tried manually shifting with no result. It is acting like someone is letting off the clutch after 20 seconds of running. In the first 20 seconds though it will shift fine from first to second.
Kaikias
OK I am writing in here what the solution was just incase someone searches and has the same problem
Turned out that the transmission filter was clogged not allowing enough fluid to the torque converter. I Removed the pan and cleaned the magnet, pan, and replaced screen.
Reno
Car: 89 S13, boosted.. RAWR..
i have a similar problem.. i would get a new transmission
