auto transmission noise?
GatorG35c
Car: 2006 Infinity G35 coupe
i have a slight nosie comming from the transmision, only on cold starts when shifting from 1st to 2nd maybe right before it shifts kinda like a spooling noise.. anyone have this problem? sent it to the dealer and ofcoarse they didnt get it to make the noise... any help thankful,,,
zozoka1212
Car: 08 Infiniti G35x
I had a Saab 9-5 before my G and had the same problem. I took it to the shop. They flushed the trani and put some better trani fluid in. Did the job. The noise disappeared instantly.
zozoka
mks8882
Car: 2003 G35, 1995 F150
Does it only do it just the one time after a cold start? Or everytime it goes from 1st to 2nd? My '03 does the same thing when it has sat for a while then the during the first shift from 1st to 2nd you hear a "thrrr." After that first time it doesn't do it again until it has sat for a while. I was told on here that it was my ABS doing a self check
GatorG35c
mks8882,, yes that exactly what mine is doing only when it first shifts from 1 to 2nd,, 1 time then when i let it sit over night it will do it again only once,, did they say its something ill/you will have to live with???,, thanks for all inputs......
smockers83
Car: 2006 G35 Coupe
gator, if it occurs every time you start the car, its your ABS going through the self check. completely normal and nothing to worry about...always happens on the first shift from 1st to 2nd. for piece of mind, you can read up on this in your manual (just look up ABS in the index) and this was also explained to me when i bought the car so i wouldn't be running to the dealership right away.
GatorG35c
ok thanks smockers, thats exactly what i did,, took it to the dealership when i first started hearing it,, and they couldnt find anything.. thanks again
