On the Malibu you can indeed remove the pan and change the fluid and filter. There's also a filler hole. There's no dipstick, but there's an oil level screw somewhere on the bottom.gibbo80 wrote:i am not possitive because it has been a while but i was always told by my friends with malibus and by the dealers when i was looking at them that malibus had sealed transmissions and you cant have the fluid changed. When the transmission was bad it was bad. But if i am wrong anyways sounds like a bad transmission to me
Altough I don't know how the transmission got to this heat problem. It's not like my dad races the engine, and these were mostly highway miles. The car was a rental or lease for the first 15k miles, so I'm thinking that may have a bit to do with it.Sean wrote:This sounds like the rubber in the trans getting hard from either heat or high miles. More than likely heat being that the car only has 60K on it. Unfortunatly the only cure for this is to install a new paper rubber kit. Which is basicly overhauling the trans. If you are going to pay for the expense of installing a paper rubber kit you might as well overhaul the whole trans since you have to totally disassemble the whole trans to do this. If you want to buy some time let the ccar warm up completly befor trying to move it. Revving the motor to force it to move is not good for the clutches. Cost on an overhaul for this trans should be around 1600 - 2000 in my area anyway
I actually suggested him selling it when it warms up and getting a Maxima. Probably 4th gen since we wouldn't get much money for the Malibu. Everything else is fine it's just that stupid transmission. The engine should be going strong since it's the same thing chevy used in their cars for a while (3.1 v6). Might just rebuilt it for $1500 and keep it.Mr1der wrote:I'm gonna have to go with TMS....
tell him to get a Crown Vic or something...
or you know...an Altima
Do some NICO searches. The parts are about $30-$60 and theyre quite easy to install. You can even go over the top and get one with its own cooling fan. You just take the fluid lines and attach them to a cooler located behind the radiator.Slider wrote:I actually suggested him selling it when it warms up and getting a Maxima. Probably 4th gen since we wouldn't get much money for the Malibu. Everything else is fine it's just that stupid transmission. The engine should be going strong since it's the same thing chevy used in their cars for a while (3.1 v6). Might just rebuilt it for $1500 and keep it.
I'm not sure if the car comes with a transmission cooler or not. But how would I go about installing one? and is it a hard task?
Thanks for the replies everyone
HEY! I didn't like it that much at first, but it grew on me. But it doesn't look that good in anything other than black. The red, silver, and while I see all over are not nearly as sexy as my dad's black one. Besides, it makes the looks on the ricers faces all the more pleasing when they get wasted by a curvaceous lux-mobile with FOUR DOORS (gasp!). (I've noticed that most ricers (that I've met) seem to thing that additional doors (beyond two) make a car automatically crappy and slow...)I'm not the biggest fan of the headlights, but the bumper echoes the Z32, and the car is one, big, gorgeous curve that never ends...Mr1der wrote:the newest Max is ugly anyway
