NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Jan 09, 2004 7:28 pm
no you are looking for voltage with it plugged in and key on. you back probe the connector with a pin and measure the voltage as you rotate the throttle drum. car is not running but key is on.
If you set it so it rests at .5v your closed throttle switch will be right about where its suppose to be.
