Auto trans. problem. Torque converter?
220Maxima
Car: 1995 Nissan Maxima
I recently started having trouble with my 95' Maxima. Its an automatic transmission and when its shifting it sometimes slips and travels into higher RPM ranges without the power output. I can no longer give it full throttle because it hits the redline repeatedly as if there is a rev-limiter and will not shift. I am wondering if this is a problem with the torque converter or if anyone has any ideas of what it could be. My fluids are new, I recently flushed the entire trans. fluid. Thanks
maxhopper
Car: 02 Maxima SE 6spd
The 4th gen automatic transmissions are notoriously bad. If you have that kind of slipping going on, I would suspect an internal failure of some sort more so than the torque converter.
220Maxima
Thanks.Any ideas at all?
maxhopper
You should be able to find a low mileage transmission from a junk yard for under $500. That's the route I took.
oilerftbll84
Car: 2002 Maxima
yeah thats the best thing to do. just change the transmission.
dr-rjp
Car: 1998 I30
220Maxima wrote:I recently started having trouble with my 95' Maxima. Its an automatic transmission and when its shifting it sometimes slips and travels into higher RPM ranges without the power output. I can no longer give it full throttle because it hits the redline repeatedly as if there is a rev-limiter and will not shift. I am wondering if this is a problem with the torque converter or if anyone has any ideas of what it could be. My fluids are new, I recently flushed the entire trans. fluid. Thanks
Flushing the transmission was your first mistake, sorry to say. A smart mechanic would have warned you.
However, all is not lost. At the risk of getting flamed by folks who have never done this before, I would try adding a bottle of Lucas Transmission Fix. When my '92 Max started slipping between 2nd and 3rd at 160k, I added Lucas and got another 143k on my transmission (that's 303k total miles) before I had to have it rebuilt. I've recommended it to about a dozen other people and they have gotten outstanding results.
first, you have to make room fo the Lucas. Just drain out about a quart of transmission fluid, preferably through the drain hole after you remove the plug with 1/2" socket head -- it fits perfectly inside the plug. Don't do this with a hot engine because you will burn yourself on hot oil! The plug is located towards the bottom of the transmission's side, and is horizontal to the ground...meaning that transmission fluid will come gushing out unless you are very careful and hold onto the plug with your fingers when you get to the last two threads on the plug.
You can also use a hand pump with a narrow hose inserted down into the filler tube to pull out the exact amount you need.
It's best to do it right after the engine reaches operating temperature.
You've got nothing to lose because the Lucas will not harm your transmission, and if it does not help, then the plates and bands inside need to be replaced anyway.
After you do it, come back on and give us an update.
220Maxima
thanks, will do
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
I am running Lucas Auto Tran in my transmission now.
It is supposed to revive the pliability of the gaskets and seals
I think it shifts better but am not sure since i changed it at thesame time I changed my transmission fluid. No harm from it has surfaced.
