Auto trans only seems to have 3rd gear..
goofynick6
Car: 1995 S14.5 RB20DET
Well, after some good forward, reverse, forward shifting to get unstuck in the ice, I seemed to have lost my gears except 3rd. When I manually shift it to 1st it makes no difference.
Any ideas? The trans supposedly has about 15k miles on it, was swapped from a junkyard car before I bought it. Did work perfect until this incident...
NIck
gmckey
Car: 1998 Nissan HB KC 4cyl 5spd
if you need another transmission, I got one... but I'm in Texas... let me know.
[email protected]
daz1320
Car: '93 vert
I have a rebuilt one in GA....
yellow_jacket
Car: 95 240sx
There is a chance the ecu has switched it into limp mode. Is the OD light flashing or on? Try resetting the ecu. If that doesn't fix it, the transmission is done.
goofynick6
OD light is not flashing at all, and I don't want a new transmission as I'm gonna be doing the RB25 swap inthe next couple of months, just that for the time being it really sucks!
Nick
goofynick6
Just to update, went out and started the car the next day, and all was fine. Shifts normal. Must have been an ecu code or something. Thanks for help.
Nick
