radioflyer »
https://forums.nicoclub.com/radioflyer-u37445.html
Sun Feb 19, 2006 5:47 pm
Hi Guys This is in regards to the inherent problems that seem to plauge the automatic transmissons in the cars. I'm talking about shifting problems the key is prevent the problem and you can cure it . I'm sorry to say to all of you that are already experiencing problems the damage is probably already done unless your one of the luckey ones that might have found a cure in a bottle . Okey here it is I talked to a very good friend the other day that also happens to be a very respected transmisson guy who has also has had quite alot of experience with this tranmisson. These transmission's have a problem with burnning up planetaries because of overheating the cure is as simple as installing an aftermarket transmission cooler and for added security have it flushed and serviced with synthetic transmission fluid do this and you should have long service . To answer another question why does this problem seemto be worse in converts well put simply there heavier more wieght means the transmisson has to work harder well hope this helps
