auto transmission slipping
mattscar
Car: 1989 240sx, 1992 Miata
when I drive my car and depress the gas pedal about 3/4 the way it slips. The sound is similar to when the clutch slips. Its really irritating cause when it goes to 2nd the car jukes me forward. I dont like it! what is the problem with it?
Red coupe
Car: 92 Nissan 240sx Coupe
and you drive a 1982 datsun 200sx?
have you checked the fluid level?
da40
Car: 1995 SE 240sx
need new clutch or u have no fluid check the fluid level first
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
torque converter slippage on the turbine side. it must have f***ed up flow on the turbine side (transmission side). check the fluid levels, smell the fluid. if it smells worse than a decomposed animal, then u have burnt fluid. i suggest looking to get a new torque converter, because more than likely the turbine side is bad.
