auto transmission replacement?
240sxBobby
Car: antiques
[FONT=arial]Hi, This is my first time with this forum. I have a 1991 240sx and need to replace the auto transmission. I can't get to the bolt on the top to the transmission? does anyone have a idea on how to get to it? Thanks for the HELP!BOB/FONT]
NISTECH
remove the transmission mount and allow the tail weight of the trans to tilt the engine down in the rear.
240sxBobby
Car: antiques
I have the mount out and the transmission down. I still can't see it? I went in with a 3' extention and tried to get it from the tail of the transmission but it won't go pass the hump in the bell housing? Believe me I have tried every thing today!
NISTECH
push the trans up with a floor jack and see if you can get a wrench on the bolt from the top from the exhuast side. when doing it from underneath and the trans sagging you still need to use a universal socket to get on it and you have to use an angle that if you were to draw a straight line from the bolt to the speedo pick up.
