Auto transmission question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
PaulRay
Car: 09 Versa s
I have a 09 versa HB with the reg auto transmission in it. I've noticed when I get on the interstate and the car isn't fully warmed up, that at 70 mph it'll read 3200 RPM. It almost sounds like it's stuck in the passing gear. Then after a few mins the RPM will kick down to 3000 RPM. Is this normal, makes me wonder why I'm only getting bout 28 mpg since I drive interstate all the time and the RPM is a lil higher?
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
My '09 does it also, but I'm "interested" in the reason why also. Mine will be at 3100 at 70 and will lower down to 2800 after a minute when it settles in. It's like a overdrive to the overdrive gear. I am usually around 32mpg, but I tend to drive 50% of the time at 60mph rather than 70.
conversation
Car: Versa 1.8 S HB
I also have an 09 versa HB with the reg auto 4 sp trans. I'm pretty sure my tach is at 2800 at 70 mph, and stays there. at 60 mph I'm at 2400. It is higher rpm than the typical 4 cyl car, I think. I can get 35 mpg, if all highway, if I keep it between 60 and 65 mph, in summer.
Modified by conversation at 10:32 AM 2/16/2010
CrankyVersa
Car: 2010 Versa 1.8 hatchback SL
My cvt usually sits around 2000 or under a bit , no issues so far.
V-Man
It could be the transmission torque converter kicking in.
shiryu0
Car: 2008 Nissan Versa
V-Man wrote:It could be the transmission torque converter kicking in.
that, and the car is trying to warm everythin up to operating temp.........
Shad0wXCalibur
Car: Nissan Versa SL Sedan
It's just the lock up torque converter. It sorta acts like a 5th gear but it's not a gear. It locks the transmission to the engine like a manually driven car to stop the slipping at cruise thus reducing engine rpm, increasing gas mileage, and reducing wear on the transmission. It won't lock up until the car has reached a certain temp. The CVT automatics (they have it, too) lock up early which is why it has that rpm surge when you take it off then it suddenly drops.
br4dysays
Car: 06 Nissan Altima SE-R
yeah this def has to do with the operating temp.
if i head out onto highway speeds even right after the car 'blue light' goes out, it'll stay @ higher RPMs for a few minutes til everything is warmed up then it'll go down to its usual.
i avg about 29mpg roughly, but do a mix of driving.
sfd6532
Car: 2010 Nissan Versa 1.8 S Hatch Back
My truck stays in drive until it is warm and then shifts into overdrive at normal temp. It sounds like this does too.
08versailles
Car: 08 Versa SL 6sp
09 Altima 2.5S cvt REAR ENDED and WRITTEN OFF
13 Charger SXT 8sp auto
Shad0wXCalibur wrote:It's just the lock up torque converter. The CVT automatics (they have it, too) .
I did not know the CVTs also have a lock up torque converter.
No wonder they can get better mpg highway.
How soon [from stand still on warm engine/transmission] does it lock up?
Sorry 'bout the nerdy techie question :blush:
CoupeVQ35CVT
Car: '98 Lexus GS400, '91 'Yota Land Cruiser
'09 Altima Coupe 3.5SE CVT, '06 Sentra 1.8 SE
From what I understand, our CVT locks up at 20 mph regardless of temps. This is because the CVT belt is doing the gear "shifting," so there is no need for any slippage, except when the engine is idling at a stop light etc. (since we don't have a real clutch to disengage the CVT at a stop).
Return to “Versa Technical Discussions”
