s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Mon Jul 19, 2004 4:25 am
well, it aint looking good. if you tried a stall test and the brakes would not hold, then your brakes may really suck or the stall may be way too high. does not really matter, heres why. if you unplugged the tcm and it drove around in first, the trans is blown. sorry. without the tcm to command gears, you are stuck in 3rd. if that dont happen, its internal. the o/d switch can only keep you in/out of 4th gear. if you want to try jumping it still, just jump it from anywhere you can find 8v. its the 8v i want to get jumped over there. does not matter where it comes from. that 8v will simulate a fully functional kickdown switch to eliminate it as a source of probs. however, we already know the prob is internal.
