jackchoo »
https://forums.nicoclub.com/jackchoo-u33124.html
Sun Oct 02, 2005 3:13 am
Hi, been having intermittent issues shifting from 1st to 2nd. The gear seems to get stuck and recovers if I rev >5k sometimes and for those times it doesn't recover, I have stop the car, turn off engine and restart again, then it back to normal. Happens about once every day. Damn annoying and esp dangerous when entering a motorway.
The transmission self diagnosis yields a TPS issue when this happens. Changed TPS, but the problem still persist. Checked continuity from TPS to TCU and ECU everything seems ok! Did a transmission fluid flush (10L) and still the problem exists!
I measured the TPS with a multimeter and jiggled the harness and wires but yielded no problems on the readings.
What else can I do? Could the wires from TPS to ECU and TCU be stuffed intermittently? Appreciate any ideas!!
