1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Tue Mar 08, 2005 5:34 pm
As far as interior wiring, I just left the plugs in there and tucked them under the carpet. Put the console on and no one will see them hanging.
Im not really sure about wiring the park/neutral switch to the clutch pedal, that sounds pretty complex and time consuming to me. I finished wiring the neutral switch in like 5 minutes the way I did it. Jumper the two wires together, and you're done. You dont have to pull the fusebox out, just unplug the 3 large plugs behind the fuse box so you can get to the small plug on the bottom (which is the park/neutral switch).
The reverse lights dont get jumpered together. When I took out my auto, I cut the 3 groups of wire that went to the transmission. When you do that, you unplug those 3 harnesses behind the fuse box and pull them out. All youre left with is the 3 plugs. You cut the blue/green and green/yellow wires coming out of the back of the middle plug. From the wires coming out of the fuse box, run a wire to each side of the reverse light sensor on the manual transmission. My transmission sensors were all cut with only about 6 inches of wire dangling, so I do not know, but I dont think they could just plug into the plug behind the fuse box. The plug it comes out of isnt just for the reverse light sensor, it has a group of like 6 other wires that run to the auto and I dont know what they do.
Sorry I can't answer your master cylinder question, I haven't mounted it yet. Look under the dash and you will see where it belongs, there is a large circle with two smaller circles on each side of it. This is where it mounts, so just look at where it is in the engine bay.
Im not trying to say my way is the best and only way, but it is the only way I could find to do everything. It was really simple, wiring took like 10 minutes, hardest part was unplugging the plugs behind the fuse box. Also, dont forget to plug the speed sensor back in. Its the little (brown I believe) plug that hangs down on the passenger side of the transmission. Plugs right into the manual, the long wire that goes from the back to the front of the transmission with the plug on the end. My cardomain page will have all the info (with a good amount of pics) when I am finished, which should be this weekend.
