96_S14_SE »
https://forums.nicoclub.com/96-s14-se-u2649.html
Thu Nov 07, 2002 7:14 am
Yes you will have to drill the firewall not swap firewalls. You can see in the rubber sound deadning lining a semi cut area next (left of course) to the upper portion of the break pedal assembly, go tear that off. Thats where the MC rod goes through and the 2 bolts as well. Also the bolts on clutch pedal assembly go through the firewall and attch to the MC with nuts. So you probably wont need 100% accuracy just a little larger sized drill bit and nicely torque down the bolts.
And no, the connectors are not quite the same. The main harness has 2 connectors to the lower harness (IIRC go take a look in the morning Ill be going autocrossing hehe), and you will need this lower harness. It will plug directly into the sensors into the 5 speed (of corse) and then plug into the main hrness via a different connector. The clutch pedal connectors should have wires prewired as well but I never looked, probably should tommorow for sh**s and giggles.
One of the lines in the auto transmission sub harness goes to the dropping resistor (funky little box right before the drivers strut tower with 2 wires used to control line pressure in the transmission), which a 5spd has no use for.
