auto to manual
evotech240sx
Car: 92 240sx fastback
all right i know this has been done a lot of times already but i lost the info to all my things i need to make my auto 92 to a manual. well i know i will need to get the manual drive shaft, the transmission, the ecu, new cluster, fly wheel, clutch, shorter brake pedal (width wise), clutch pedal, master cylinder pump???, and im not sure what else do i need. can u guys help me out and can u guys alos give me a ruff estimate on how much this whole entire thing will cost. i figure it will be about 1g. so thats pretty much my price range. thanks for the help......
Hijacker
Car: '92 240sx Convertible
'94 F-150
clutch MC and SC. also, do a search. this topic has been discussed a thousand times
yeswepromise
clutch lines.clutch hardline will cost you about 20 dollars at the dealer.
CanadianCoch
SEARCH !i JUST posted EVERYTHING you need for the swap, as WELL as a walkthrough!
if you know it's been covered a lot of times why not look it up?
Dr.
574-240sx
Car: Nissans, Toyotas, Subaru
http://www.nissaninfiniticlub....anual
The search button really does work. Nick
