Auto to manual
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
When doing the five speed swap do you have to have the five speed drive shaft.
And can you use the s13 pedals in the s14 body.
Modified by Lonismos14 at 11:07 AM 12/5/2009
JustDriftMore
Car: 89+91 ku-pe
yes you need a manual drive shaft and i would assume theres no problem with the pedals
Doya
Car: '95 240sx KA-T
The s13 pedals work fine in the s14. The s14 pedals sit a little crooked in the s13 though. Everyone always says that you have to use the manual driveshaft because the auto is too long. I was think about maybe cutting a little bit off of the input shaft on the auto so it would be the same length as the manual.
I just finished my 5 speed swap and I still have my old auto driveshaft lying around. I might measure the length of the manual, and cut the auto down to size and see if it works. Just for sheetz and giggles
Lonismos14
hey thanx man
Doya
Car: '95 240sx KA-T
Yeah, I was curious if it would work or not. I'll try it when I get the chance sometime. I can't do anything now because of the snow
