maxima278 »
https://forums.nicoclub.com/maxima278-u20438.html
Mon Jan 10, 2005 1:39 pm
I don't necessarily have a fuse box on the passenger side, unless I'm just blind, are you talking about the place where the wiring harness actually plugs into the ecu? If you are talking about the fuse box under the hood, I am taking that off of my parts car when I change the engine/transmission. it is already manual shift. The wiring harness on the car I am working on is toast. literally. By the way below your post it says you have a shudder? Check your driveshaft for any type of irregularity. Just the slightest thing can throw it off.thanks
