nipo »
https://forums.nicoclub.com/nipo-u27692.html
Wed Oct 27, 2010 7:08 pm
I have the option of buying a 95 se auto for a good price. The interior is mint and the exterior is about 95% perfect. The engine is strong. My plan for the car is to build a KA-T. My question is, how hard is it to come across all the parts for a auto to manual swap? I've read all the write ups (years ago and earlier this week). I know it can be done for $200-$500 if you can get your hands on used parts etc. I don't mind paying a little bit more to get my hands on things quicker, and hell i wouldn't even mind paying someone some money to track the parts down for me (extremely busy with 2 jobs). So again how hard is it to come across all the parts listed in the s14 auto to manual write up.....>
5 speed transmission from an S14 (you could try an s13 if you want)
5 speed Driveshaft front and rear sections (this may differ if you have ABS/LSD)
Flywheel (new or resurfaced)
M/T flywheel bolts (A/T bolts are too short)
Clutch Kit (Clutch, Throwout bearing, Pressure Plate, alignment tool)
Shifter assembly (plate, lower rubber boot, upper leather boot, finisher plate)
5 speed Crossmember
Clutch Master cylinder
Clutch Slave cylinder
Clutch hardlines
Clutch rubber line and dampener line (which you may want to remove anyways)
Clutch pedal assembly
5 Speed Brake pedal assembly or a cut brake pedal (automatic pedal is much larger)
Bellhousing bolts for a 5 speed bellhousing (some of the A/T bolts can be reused)
Bolts to hold Pressure Plate to Flywheel (same thread as bolts that hold shifter to transmission, but a tad shorter)
