evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri May 13, 2005 8:00 am
well if it's a 280Z (75-78) then it's easy enough to swap the whole pedal box, easier than trying to swap out the big brake pedal for the smaller one and add the clutch pedal, just pull the dash and swap the pedal box, of course you'd need the clutch master cylinder and the hand and soft lines, and for the early cars I am not sure but you might need the driveshaft
if the car is a 280ZX (79-83) then the pedal box swap is a lot harder and the same parts are needed and the 280ZX auto shares an output shaft with the Turbo 5 speed, if you use an N/A transmission you'd need the driveshaft as well, and of course when swapping driveshafts you need to use a 2 seater shaft in a 2 seater car and 2+2 shaft in 2+2 cars, t
the hardest part is pulling the dash on either car but if you take your time and read the manual you'll find it's much easier than most cars, and just to be clear the transmission moutsa re all the same so you won't have any trouble there, and in converting to a manual you'll need to pull the flexplate and spacers and replace with a flywheel also the engine backing plate should be swapped as you won't need the removable lower panel to access touquec onvertor bolts any more
