auto to manual swap
95-240T
Car: 95 Nissan 240sx se
Can you use a s13 clutch pedal assemble on an s14 and what do I do with the shift lock control.
Structure240sx
u can use the s13 pedal, it seems to sit a little farther back. once the auto is out you dont have to worry about shift lock, or am i thinking of the wrong thing?
the top plug behind the fuse box from the auto harness has two wires. cut these tow wires and splice them together and the car will start
gepeto
Car: 1995 S14
Other S14 auto/manual swap question:
How much would you pay for clutch line, master and slave cylinder, clutch pedal
95-240T
Sorry it has been awhile since I check my file. I have a S13 shell with the lines in it that I thought I could use.
There are two components on the brake pedal that I thing is the auto shift lock that is what I am wondering what to do with.
