SHIFTrl240 »
https://forums.nicoclub.com/shiftrl240-u8550.html
Mon Mar 22, 2004 4:09 pm
there isnt any reason to get a brand new pedal assembly from the dealer... just get one at a local junkyard, although it is a ***** to get in and out. if you are able to, just cut it down til you can fit the pedal cover on it. believe me, i did the pedal, it aint exactly easy to get to it. you have to take off the brake booster from the engine bay and take half the dash apart to drop the steering column to get it out and to get to the bolts. even then, if you don't have swivel extensions, then you still won't be able to get some of the bolts very good.
