auto to manual swap question
az240wanted
So I searched a little and couldn't find the answer so, Are there any differences on the engine between an automatic and manual transmission trucks?
Also, will a manual transmission from a 240sx bolt to the ka24e block on the truck or are the bell housings different?
Thanks,Matt
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You'll need another truck transmission. They're not the same. You'll also need to swap over the flywheel to one from a manual.
You'll need the pedal, linkage, clutch master, as well as a few electrical changes. Over on http://www.nissan4wheelers.com, a friend of mine recently did this on his WD21 Pathfinder and found it easiest to just buy a donor truck and then part out the rest.
az240wanted
As far as the engine goes, do any sensors or anything besides the flywheel and clutch need to be switched out?
Thanks,Matt
WWJD
no. I think the only thing you'll have to do is fool the nutral safty switch
