auto to manual swap problem!!!!! HELP.
ourmartyr
Car: 1997 acura cl 2.2, 1990 240sx, 1990 240sx RIP(parts)
alright i've swapped transmission's in my car... 90' 240sx ka24e... the car is for some reason not getting ANY fuel or spark. i've followed every step to swap it out, checked all the fuses... all the grounds... and the timing! the car turns over but will not fire... I've also searched around this website everywhere and couldn't find anything useful for my situation. guys please help me!
ourmartyr
also i just checked the wire that plugs into the coil... no power. HALPPPPP
ourmartyr
BUMPPPPP
motoman399
Car: 98' wrecked (RHD coming soon) 240
did you do any wiring when you did this? this should not be a problem. if you did wiring of any sort undo it and try that
tero404
Car: 93 240sx
this is kinda a tough one.. last no spark/no fuel problem i heard was a timing belt but u say ur chain is on right.
maybe its nothing u did ourmartyr, maybe there is a sensor thats badi believe the distributor acts as a cam position sensor aswell. u can check that.
if that works, make sure the coil is giving it power.
as for ur fuel delivery problem... well... the only thing i can think of right now that controls both is a ecu and some fuses/relays
thats my two cents. keep us posted
